V 17.1.04 crash on VLAX-RELEASE-OBJECT
Hello,
an Visual-LISP code, which works perfectly in AutoCAD, crashes in BricsCAD V 17.1.04:
The problem seems to be at vlax-release-object:
" ; ----- Error around expression ----- (VLAX-RELEASE-OBJECT OSTARTCOLOR)"
Is there a problem known at VLAX-RELEASE-OBJECT?
Thank you in advance for the answer, Albert0
Hello Albert,
to get (free) support from one of the Bricsys analysts please file a support request, they will be glad to help you out.0
