LSP command equivalent?
Is there an equivalent to the LSP command from AutoCAD? I use it to determine what setvars have been set in a current file.
Thanks,
matt
0
I don't think there is such a command in BC. But you can export the settings of dwgs to .csv files and then compare those files.
Look for the appropriate button at the top of the _Settings dialog.0 -
of cause it is. Its the same like AutoCAD
0 -
Hi, Martin,
there is no LSP command in BricsCAD :-)
many greetings !0 -
oh, sorry - you are right. BUT in AutoCAD its also not in the regular Program. Its part of the Expresstools. I always have the Expresstools loadet.
@mtaussie you can get the Expresstools 4free at the application catalogMartin
0
