Text in prompt menu is too large for the boxes it is printed in. Version 16
I'm using version 16 and running a 3rd party app that requires it. The text in the boxes for the prompt menus is clipped off at the bottom of each box. This issue also show up with the 3rd party ribbon menus. I'm running a laptop with two different displays and the problem is the same on each. We also have another station here running all the same software without this issue. As well, opening version 17 on this laptop is perfectly normal. I've uninstalled the 3rd party app as well as the BricsCad application and reloaded the BricsCad with the exact same results. Wondering if anyone might be able to help? Thanks
  • Seems, you have set the font/scaling size in Windows' Display Properties to a very large factor (200% or like that) ?
    maybe using a smaller scaling factor will help ?
    You might also try V17, where we improved the GUI for HiRes displays ...
    many greetings !
Welcome!
It looks like you're new here. Sign in or register to get started.
