Save drawing - same folder of last openig
Hi guys, my proble is: when I open a drawing and then create a new drawing, I need to save the new one in the same directory/folder where I open the first drawing.
Now the directory of saveing is the same of las saving. I need to change it with the opening folder.
Many thanks in advance for your precious support
Bye
Francesco
Your question is not entirely clear: 'last opening' or 'first drawing'?
You can change the REMEMBERFOLDERS setting to Off (zero) to use the 'start in path'. If you then start BricsCAD by double clicking a .dwg file, the file's folder will be the default when saving new drawings.
0 -
Yes !
REMEMBERFOLDERS is correct. After setting to off (0) it save the new drawing in the last opening folder, as i wanted.
Thank you alot Roy Klein Gebbinck0
