Best aplication for mechanical and Electrical on BricsCAD?
Hello, what are the best aplications for mechanical and Electrical for installing on BricsCAD?
  • I can only speak to electrical. From what I've seen the answer will depend on where you work. European standards are quite different from United States standards. The best solution also depends on what type projects you work on. Industrial drawings require different tools compared to residential drawings.
    My solution was to write my own tools rather than try to find an application. I would rather set my work procedures and have lisp routines to support those procedures than have to adapt how I work to fit an application I bought.
  • I work in Mexico with USA standars
Welcome!
It looks like you're new here. Sign in or register to get started.
