Combo tools for TextStyles and DimStyles
Hi,
I'm looking for combo for TextStyles and DimStyles.
I'd like to have them visible on screen as in Autocad. See picture.
It is the same as layers control, linetype control ......
Thanks
0
These controls are available. In the _Customize dialog switch to the Toolbars tab and look for the 'Controls' node in the right panel.
Note:
There are fields for the text style and dimension style in the Status Bar. You can right-click them to change the style.0 -
Bricscad, any chance in a future release about placing the mleader style in the same Status Bar as the two items Roy mentioned above?
0
