Join pointws by Pline
Hi,
I'm fairly new to BricsCad. I have about 20,000 points plotted which I need to join with a polyline, is there a fast way to do this? I can't export the points and then plot them as a polyline because they don't plot in the correct order and it's important the polyline is made in a specific order. Since the points are not numbered, I'd like to join points separated by a distance of 1m or max 1.10m.
Any help is welcome!
i don't think this is posible without an seperate develloped tool. For better understanding, you'll better upload an drawing, where everybody can see the requirement an the solution.
Martin0 -
Hi, I ended up finding another way to achieve this using different software (Wintopo) to re-order my points according to a centerline. Thanks for the reply anyway!
Ainhoa
0
