Using german and english version
I use BricsCAD 64bit in German. To understand posts in english forums or to find out the english versions of command options it would be useful, to have the english version as well.
Is it possible / allowed to install the english version in 64bit (or at least 32bit) on the same machine without side-efects and without loosing the second license for homeoffice ?
Thanks a lot
Mathias
0
Suggest you put that question in a support request to Bricsys - https://www.bricsys.com/en-intl/support/#88
0
