mtext and leader entities
When will mtext be fixed so it won't show "varies" when you try to edit large text entities? Also, when will we be able to use osnaps on leader entities? One final note: draw a closed polyline entity - select it and try to rotate it by picking points - it doesn't work! Now draw a line. Go back and select the closed polyline and try the rotate again - now it works!?
0
I tried to reproduce the 'rotate closed polyline' problem, but I could select its vertices without any problem.
0 -
Selecting the vertices is not the problem - rotation by selecting a rotation point does not work. It will work if you enter a numeric value for the angle of rotation, but not if you try to indicate the angle by picking a point.
0
