How to restore original layer settings of an x-ref
Hello,
is there a utility which would restore layer settings (layer type, line thickness...) for a picked x-ref?
I.e. - to "scratch" layer setting which were assigned later in the "hosting" drawing, like if "VISRETAIN" was turned on?
Thank you in advance.
Best regards,
Honza
0
normally you just have to "detach" and "reattach" the xref in the manager. (the tick boxes)
0 -
oh yeah, and visretain has to be on for this
0 -
You might like XRESET, contained in the attached lisp.
0 -
Should have had a second look at the script before posting: there was a typo in the dialog description that caused a zero-height image-button.
Fixed this, and while I was at it, renamed the dialog to correspond with the lsp file name (which is good practice).0
