Displaying Z Values
Greetings!
I'm quite new with BricsCAD. A have a set of points and I would like to display their Z values (heights). Is there a way to do this?
Thank you very much!
The command _id will display the coordinates of a selected point on the command line. Are you looking to extract the values or to put them in a label in the drawing?
0 -
Id will show the coordinates in the command bar. I would like the Z-values on the drawing. Thanks!
0 -
You can create your own block for this purpose:
https://forum.bricsys.com/discussion/comment/34433/#Comment_34433
In your case you need the Z value.Alternatively it is possible to use a custom (Lisp) program to automatically add texts that display the Z coordinate of point entities. If you do a WWW search you should be able to find plenty of examples as this is a recurring question on the forums.
0 -
ok thank Roy
0 -
I meant thanks!
0
