Edit table borders
Hi there,
Just an incovenience we're experiencing when changing the borders of tables. In AutoCAD, you are able to change the "ribs" of the tables but you cannot do the same in BricsCAD. I understand that the table is a relatively new feature. I can see that there are buttons for changing the ribs but not available for use yet. Will this be implemented soon?
0
The appearance of a table is controlled by the Table Style. See the TABLE and TABLESTYLE commands in the BricsCAD Help under Command Refernce/T
0
