Formatting rules of PRV-files
This works (created by Descoder.exe);;; Visual LISP make file [V1.0] test saved to:[D:/test] (PRV-DEF (:target . "test.vlx") (:active-x . T) (:separate-namespace) (:protected . T) (:load-file-list (:lsp "a.lsp") (:lsp "b.lsp") ) (:require-file-list) (:ob-directory . "OutObj") (:tmp-directory) (:optimization . st) ) ;; EOF
This modified file does not work:;;; Visual LISP make file [V1.0] test saved to:[D:/test] (PRV-DEF (:target . "test.vlx") (:active-x . T) (:separate-namespace) (:protected . T) (:load-file-list (:lsp "a.lsp" ) (:lsp "b.lsp" ) ) (:require-file-list) (:ob-directory . "OutObj") (:tmp-directory) (:optimization . st) ) ;; EOF
Same problem here:;;; Visual LISP make file [V1.0] test saved to:[D:/test] (PRV-DEF (:target . "test.vlx") (:active-x . T) (:separate-namespace) (:protected . T) (:load-file-list (:lsp "a.lsp" ) (:lsp "b.lsp" ) ) (:require-file-list) (:ob-directory . "OutObj") (:tmp-directory) (:optimization . st) ) ;; EOF
Is there a way to make the Descoder.exe more tolerant to PRV-formats?
Dear Peter,
please send us your PRJ/PRV files which make problems by a support request ... just for the records;
of course, I will check to make DEScoder more tolerant / robust here ...
many greetings !0 -
Fixed via Support request.
Thanks for the great and quick support!
0
