XRC error: XRC resource "BMP_16_DM_DELETE" (class "wxBitmap") not found
In the end I got rid of the error message (at least for the time being) by done a reset to default in the CUSTOMIZE window but only doing the RESET CUI and not the reset PGP. After that it was rebooting the program, removing and re-adding my CUI's
0 -
I got the same issue....
I'll use your indications!Thanks
0
