Move . Copy . Rotate
I am using version 18 of BricsCad. Is there a way of combining move . copy . rotate in one command? Instead of using 2 or 3?
The Manipulator rotates, moves, mirrors and scales entities. Keep the Ctrl-key pressed while starting an action to manipulate a copy of the selected entities. See the BricsCAD Help under Command Reference / M / Manipulate.
0 -
@Harvey Hampton said:
I am using version 18 of BricsCad. Is there a way of combining move . copy . rotate in one command? Instead of using 2 or 3?If you mean you have a particular series of operations that you do frequently in the same order, you can make a custom command that does the whole operation as one command, using Lisp or one of the other programming languages, or maybe with a script.
0 -
its an function included in the ExpressTools
0 -
Thanks.
0 -
Thanks for all this information. How do I obtain express tools?
0 -
Thanks again.
0
