adding materials to doors windows in Linux
Is is possible to add materials to windows and doors in linux? I can't edit the dynamic block. I'm stumped.
0
Don't you mean BIM component instead of Dynamic block?
0 -
Here is already a thread where Louis explains how to change
the referenced external Door Presets into local one which you can edit :
https://forum.bricsys.com/discussion/comment/36043/#Comment_360430 -
Thanks!
0 -
@Roy Klein Gebbinck said:
Don't you mean BIM component instead of Dynamic block?Yes, BIM.
0
