LISP cond predicate / test for text
Hi Folks,
Trying to learn a little LISP and make a few productivity tools for myself. I put together the attached routine as I put a lot of slots in sheet metal panels where they bolt together. But, I'm stuck can't find anything on the web which suggest I probably just doing it the wrong way. I am using a condition to run different protions of the code to give either a slot with a full rad at each end or rectanlgular slot with filleted corners. Snippet below I am just not getting a match on RADTYPE = "Filleted"
(initget 1 "fullRad Filleted")
(setq RADTYPE (getkword "\nSelect System [Full(R)adius/(F)illeted]: "))
(cond
(= RADTYPE "Filleted")
Tried: eq eql equals none work ![]()
What the proper way to get and comapre the users choice in a cond?
Appriciate any help recieved.
Adrian
0
Forget it......I'm an idiot
Obvious typo in the end
0
