an idea for some functions to speed up the work
good morning.
I use Bricscad on mac and all in all I can work well.
it would be interesting to insert some functions to speed up the work:
ALL PLATFORMS
mechanical browser:
copy and replace or make unique= creates an independent copy of a component and automatically replaces the original.
parametric array: the components that make up the array do not appear in the BOM. (it would be cool if the array were represented by a tree that displays all the components that compose it with the possibility of replacing or switching off each single component)
MAC AND LINUX:
preview image in the file opening window.
@natural design said:
MAC AND LINUX:
preview image in the file opening window.Yes!
And in Finder too, would be great.0 -
Suggest you file a support request/feature request for each of your suggestions - https://www.bricsys.com/en-intl/support/
0
