Is Autodesk attempting to discredit BricsCAD
Hi there,
We have a client opening a BricsCAD drawing in AutoCAD and AutoCAD is (suggesting or warning) they have (or may have) a drawing prepared with an education version of CAD software. I am not sure of the exact wording. Has anyone else experienced this happen to them?
Thank you in advance for your reply.
Phillip
Phillip
0
There was a bug(?) somewhere in previous point releases of Bricscad V18 or the ODA library for DWG causing this to happen. It should be fixed with the latest point release update for Bricscad. Ask the person who submittted the drawing if they have updated Bricscad V18 to the most recent version, if not then kindly suggest them they do update to see if this solves the issue.
0 -
Good information RSW. Thanks.
0
