create MessageFilter - System.Windows.Forms
Is there a possiblity to create a Messagefilter for use in a loop?
Based on the Acad 'System.Windows.Forms.Application.AddMessageFilter(filter)'
Therefore you need to using System.Windows.Forms which seems not to be available in my C# environment?
0
I use something like this for my .NET project
using WinForms = System.Windows.Forms; using Keys = System.Windows.Forms.Keys; public class SpaceRightClickFilter : WinForms.IMessageFilter { public bool canceled = false; public bool PreFilterMessage(ref WinForms.Message m) { int WM_RIGHTCLICK = 0x0205; int WM_KEYDOWN = 0x0100; Keys kc = (Keys) (int) m.WParam & Keys.KeyCode; // check for space press or right click if ((m.Msg == WM_KEYDOWN && (kc==Keys.Space)) || m.Msg==WM_RIGHTCLICK) { canceled = true; } // never falter return false; } }Hope that helps
0
