isNamedDrawing()
I try to find if drawing is saved on hard drive or new in memory.
In ObjectARX I can find it with
curDoc()->isNamedDrawing();
But BRX don't have isNamedDrawing() in AcApDocument.
How can I find if drawing is new or saved?
Dear,
you might query the database (not the document), for its filename ... if it is a .dwt, then it is in 99% an unsaved drawing, becuase saved database/document usually has .dwg filename ...
but this might fail, if the database is actively saved as .dwt file.There is also originalFilename() as well ... maybe checking both can expose a clear indicator for a saved rawing/database ?
many greetings !0 -
Thanks.
0 -
INFODWG * curDoc()->fileName(): Drawing1.dwg * originalFileName(): C:\Users\Donatas\Desktop\Darbas\LISP\LKS94_2018.dwt : : _qsave : INFODWG * curDoc()->fileName(): C:\Users\Donatas\Desktop\Drawing1.dwg * originalFileName(): C:\Users\Donatas\Desktop\Darbas\LISP\LKS94_2018.dwt
It don't look like originalFileName() will work, but I found curDoc()->fileName()
If file new and not saved it will return only file name, without path. If drawing are saved it will return filename with path.string getFileName(const std::string& s) { char sep = '/'; #ifdef _WIN32 sep = '\\'; #endif size_t i = s.rfind(sep); if (i != std::string::npos) { return (s.substr(0, i)); return(""); }If I give result from fileName() to my function I will get file path, o empty string.
0 -
Try:
resbuf rb = {};
acedGetVar(L"DWGTITLED", &rb);
if (rb.resval.rint) {
//drawing has been saved
}0 -
acedGetVar worked, but need change to rb.resval.rint
0
