Saving drawing with certain decimal places of accuracy
I need to save drawing in dxf format with 2 decimal places of accuracy.
In autocad there is saveas options (saveas->tools->options->dxf options) in wich I can set accuracy...
Is there such thing in BricsCAD?
0
There are 2 solutions that I know of:
- Use the _DxfOut command.
- Use the Command Line version of the _SaveAs command. Use
(command "_saveas")to start it and then select the _Dxf option. Don't know why _-SaveAs does not exist.
0 -
@Roy Klein Gebbinck said:
There are 2 solutions that I know of:- Use the _DxfOut command.
Thank you Roy.
Solution number 1 works for me.
Second solution however does not. After using command _saveas I dont see dxf option (?).0 -
@marko_sikiric:
I am talking about the Command Line version of the command:: (command "_saveas") : _saveas File version R11/R12/R13/LT2/R14/LT95/2000/2004/2007/2010/2013/2018/DXF <2013>: nil File version R11/R12/R13/LT2/R14/LT95/2000/2004/2007/2010/2013/2018/DXF <2013>: dxf Enter decimal places of accuracy (0-16) [Entities/Binary/Version] <6>:2
0 -
@marko_sikiric:
I see. Thank you that works as well.
0
