List of Hatches in Bricscad
I have a routine for offsetting a 2d polyline (and then close itself) to be able to create a hatch area to represent a building.
I offer a dialogue of hatches to use, which in autocad 2019 is done with:
For Each hatchtype As drawing_windows.Data.HatchRibbonItem In drawing_windows.Data.HatchPatterns.Instance.AllPatterns
ComboBox_hatches.Items.Add(hatchtype)
Next
I cannot find how to gather all the names of all of the hatches in Bricscad.
Has anybody done this?
Cheers,
Jon
So, it turns out there is no internal storage of the patterns (available to us, anyway). You must scan the support folders for .pat files, then trawl through those, getting the names of each unique pattern.
Here is a subset of my solution (I use VB).
Imports vb = Microsoft.VisualBasic
Module Module_get_hatch_patterns_bc
Public Function get_hatch_patterns() As List(Of String)
Dim list_of_patterns As New List(Of String)
'Dim application_name As String = App.ActiveDocument.Application.FullName
' Dim currentDomain As AppDomain = AppDomain.CurrentDomain
Dim SearchPath As String = App.ActiveDocument.GetVariable("ACADPREFIX")
Dim SearchPaths() As String
Dim surfNames As System.Collections.ObjectModel.ReadOnlyCollection(Of String)
Dim projectName, pathName, extension, drawingName, ln As String
Dim temp_string_array() As String
SearchPaths = vb.Split(SearchPath, ";")
For Each SearchPath In SearchPaths
'SearchPath = SearchPath & "\UserDataCache\Support\en_US\"
Try
surfNames = My.Computer.FileSystem.GetFiles(SearchPath)
For Each t As String In surfNames
Call breakFileName(t, pathName, drawingName, extension)
Select Case extension
Case "pat"
Try
vb.FileOpen(1, t, Microsoft.VisualBasic.OpenMode.Input)
While Not vb.EOF(1)
ln = vb.LineInput(1)
If vb.Left(ln, 1) = "" Then
temp_string_array = vb.Split(ln, ",")
ln = vb.Mid(temp_string_array(0), 2)
If Not list_of_patterns.Contains(ln) Then
list_of_patterns.Add(ln)
End If
End If
End While
Catch
Finally
vb.FileClose(1)
End Try
End Select
Next
Catch
End Try
Next
If list_of_patterns.Count > 0 Then
list_of_patterns.Sort()
Return list_of_patterns
Else
Return Nothing
End If
End Function
End Module0 -
is it as simple as opening the hatch dialog and based on those names, type them into a text file?
not exactly the most elegant back end way i guess, but seems like you'd only need to do it once...0
