.Net - How to insert a Field into a MText?
To create a field in the text, I used code like this:
MText mt = new MText();
mt.Contents = “%<\\AcObjProp Object(%<\\_ObjId 1438088896>%).Layer>%”;
This works great in AutoCAD. But in BricsCAD 18 this method does not work. In the drawing not a field appears, but just text disappear symbols “\A”. In my example it will be like this:
%<cObjProp Object(%<\_ObjId 1438088896>%).Layer>%
Such an expression is certainly not perceived by the program as a field.
I tried to assign a field like this:
if (text.Contains("%<\\"))
Field f = new Field(text);
f.Evaluate();
mt.SetField(f);
tr.AddNewlyCreatedDBObject(f, true);
else
mt.Contents = text;
And yet like this
f.EvaluationOption = FieldEvaluationOptions.Automatic;
f.Evaluate((int)(FieldEvaluationOptions.Automatic), db);
mt.SetField(f);
else
mt.Contents = text;
In both cases, a non-working field is obtained. If the user tries to edit such a field, it disappears. If I use the debugger and check the status of the field after the evaluation, I always get InvalidContext.
Exactly the same problems occur when I insert field in a table.
Help please make BricsCAD work with fields.
Support ++
I have the same problem in Lisp.
Using this code
http://www.lee-mac.com/areastofield.htmlworks fine in AutoCAD for single and multiple selection.
In Bricscad it works only with one single object, with multiple elements there is also the "\A" disappearing.
0 -
...And the problem successfully migrated to V19 beta
0 -
Hi, Give this a whirl
static private bool Func(Document doc, Database db, Editor ed) { try { ObjectId id = ed.GetEntity("Get it:").ObjectId; string fc = string.Format("\\AcObjProp Object(%<\\_ObjId {0}>%).Layer", id); ObjectId mtId; using (MText mt = new MText()) { mt.SetDatabaseDefaults(db); using (var ms = db.CurrentSpaceId.Open(OpenMode.ForWrite) as BlockTableRecord) mtId = ms.AppendEntity(mt); } using (MText mt = mtId.Open(OpenMode.ForWrite) as MText) { using (Field pfield = new Field("The layer is: %<\\_FldIdx 0>%", true)) { using (Field cfield = new Field(fc,false)) { db.AddDBObject(pfield); db.AddDBObject(cfield); FieldCodeWithChildren fcwc = pfield.GetFieldCodeWithChildren(); fcwc.Add(0, cfield); pfield.SetFieldCodeWithChildren(FieldCodeFlags.PreserveFields, fcwc); pfield.EvaluationOption = FieldEvaluationOptions.Automatic; cfield.EvaluationOption = FieldEvaluationOptions.Automatic; mt.SetField("TEXT", pfield); cfield.Evaluate((int)FieldEvaluationOptions.OnDemand, db); pfield.Evaluate((int)FieldEvaluationOptions.OnDemand, db); } } } } catch (System.Exception ex) { ed.WriteMessage("\nMessage-{0}\nStack Trace-{1}", ex.Message, ex.StackTrace); return false; } return true; }0 -
So very difficult way around.... I can not even think how to screw itto my code. ...Especially when I need to fill the table with fields.
But maybe someone is useful. Thank.0 -
But maybe someone is useful. Thank.Well you did say mtext ;-)
yeah, a little more verbose, but not impossible .. so here's a version for tables
static private bool Func(Document doc, Database db, Editor ed) { try { ObjectId id = ed.GetEntity("\nSelect entity:").ObjectId; ObjectId tid = ed.GetEntity("\nSelect Table:").ObjectId; if (!tid.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(Table)))) return false; Point3d hitPoint = ed.GetPoint("\nPoint point in Cell").Value; string fc = string.Format("\\AcObjProp Object(%<\\_ObjId {0}>%).Layer", id); using (Table table = tid.Open(OpenMode.ForWrite) as Table) { TableHitTestInfo info = table.HitTest(hitPoint, Vector3d.ZAxis); if (info.Type == TableHitTestType.Cell && info.Row >=0 && info.Column >= 0) { using (Field pfield = new Field("The layer is: %<\\_FldIdx 0>%", true)) { using (Field cfield = new Field(fc, false)) { ObjectId fid = db.AddDBObject(pfield); db.AddDBObject(cfield); FieldCodeWithChildren fcwc = pfield.GetFieldCodeWithChildren(); fcwc.Add(0, cfield); pfield.SetFieldCodeWithChildren(FieldCodeFlags.PreserveFields, fcwc); pfield.EvaluationOption = FieldEvaluationOptions.Automatic; cfield.EvaluationOption = FieldEvaluationOptions.Automatic; if (table.GetNumberOfContents(info.Row, info.Column) == 0) table.CreateContent(info.Row, info.Column, 0); table.SetFieldId(info.Row, info.Column, fid); cfield.Evaluate((int)FieldEvaluationOptions.OnDemand, db); pfield.Evaluate((int)FieldEvaluationOptions.OnDemand, db); } } } } } catch (System.Exception ex) { ed.WriteMessage("\nMessage-{0}\nStack Trace-{1}", ex.Message, ex.StackTrace); return false; } return true; }0 -
I understood the meaning. Thank you Daniel!
0 -
hello, thank you very much for this productive sharing. but the part I couldn't solve was the fields made using the formula. that is, I can connect the length of a line with this method, but I could not be successful in a field that I wanted to create by multiplying the length of the line by 100. Does anyone have any knowledge about this?0
