Interior elevations
Hi,
is there a tool in BricsCAD BIM to create interior elevations? Or do we have to use the BIMSECTION and then manually adjust the section size for the desired room? I haven't found such tool.
Tomas
Hello Tomas,
There is an option 'Interior' in the BIMSECTION command, which will ask you to select BIM Rooms to generate Interior Elevations. The interior elevations will then be created automatically for each wall of the room.
Thank you Tiemen.
Howdy, Stranger!
