Shape not showing quad cursor
Hello all and Happy New Year,
I'm wondering if anyone else if having a problem with the quad cursor not showing up in Shape and what can be done to fix this. It was there when I first installed it and thought a reinstall might fix it but it didn't. Also looks like I may be missing other functionality and or toolbars. For example, I wanted to play with object snap settings but can't find where to do this. I just recently installed BC V19 to evaluate the Pro level and wondering if this may have something to do with it. Any input would be appreciated. Thanks in advance
0
You can start by checking the
QUADDISPLAYvalue in the registry.
Look under:HKEY_CURRENT_USER\Software\Bricsys\BricsCAD Shape\V18x64\en_US\Profiles\Shape\Config\0 -
Thanks for your input. I'm afraid I don't know much about regedit type values but I changed it to 1 and now it's showing up. Thanks for the help. Very much appreciated! Cheers!0
The default value for this setting is 5.
0
