SRCHPATH folder location
I am trying to get my acad.pgp into BR. I have renamed it default.pgp and copied it to C:\Program Files\Bricsys\BricsCAD V19 en_US\UserDataCache\Support\en_US. I left the top part of the default.pgp file like it was and just replaced everything under All platforms command aliases. I closed the drawing I was in (did not save) and opened a new drawing. I typed in REINIT to find the new .pgp and I get the error message "unable to open program parameters file: default.pgp The file should be in one of the SRCHPATH variables folders."
Can someone PLEASE tell me where this folder/folders are located?
Tom,
See my reply in the other thread(findfile "default.pgp")at the BricsCAD command line0 -
(findfile "default.pgp") returns nil
0 -
@tomcarver said:
(findfile "default.pgp") returns nilTry:
Copy the default.pgp to your equivalent of
"C:\Users\kdub_\AppData\Roaming\Bricsys\BricsCAD\V19x64\en_US\Support\default.pgp"
and check that the path is on the SearchPath.I'm a little suspect about your installation ... you may get benefit from re-installing or doing a repair install.
0 -
Kerry Brown, I'm still using the trial version.
0
