workspace setting keep resetting itself after closing bricscad, any idea why ?
in 2D Drafting
i'm using v18, the workspace settings keep getting lost after I close bricscad and re-open, pls help
0
If you want to save changes, use WSSAVE or else turn on WSAUTOSAVE to save automatically (which is the default).
0 -
hi, thank you for the tip. sometimes bricscad closes/crashes by itself, the when starting the app again all toolbars on the workspace is lost, not sure why
0
