Visual basic 6 applications using COM API
I assume you mean to use VBA
https://www.bricsys.com/bricscad/help/en_US/V19/DevRef/
To access BricsCAD VBA you will need a Pro or Platinum license; I'm not certain if the lesser licenses will be able to run your application without a VBA enabler.
Perhaps porting to .NET C# or VB will be a better option long term.
0 -
Hi Kerry thanks for answer but are external applications made in Visual Studio 6.
Is it possible to deploy in Bricscad store as a package to install?
Porting to .NET is a possibility.
What kind of files can i upload to the store? .Dll? A package to injstall?0 -
I don't work with VBA or VB.net.
I don't have knowledge of the requirements for the Bricscad store ( I only develop for regular clients at the moment )
The information is available here https://www.bricsys.com/en-intl/applications/developers/
... towards the bottom of the page.0
