Shade Sails
What method are users using to model shade sails in Bricscad BIM V19?
You can draw two opposite Edges as lines in top view,
pull one end of each in Z Axis up in an isometric,
use the Loft Tool to create the nonplanar Face between
both lines.Menu>Model>3D Solids>Loft
That is a simple Shade Sail, with without having its edges bend
also, like in reality.
Maybe it could be created by defining all 4 edges - as Arcs.
But Loft Tool has many options, I would check those in Help System.
I currently also do not see a way how to modify the Loft Object later
but I am sure there are0 -
Looks like usin Guides+Cross Section would be the way to go with Loft :
https://help.bricsys.com/hc/en-us/articles/360006623914-Loft
https://www.youtube.com/watch?v=AV8wukyZ9LYDMTWIST could be another (faster ?) Workflow :
https://help.bricsys.com/hc/en-us/articles/360006763713-DmTwistOr Deform Faces ?
https://help.bricsys.com/hc/en-us/articles/360013002634-Deform-faces0 -
I'm sure there are other (and better) ways but try this. Make some broad arcs for the edges, ends connecting. Grab them all and convert to a region. Use _dmdeformpoint (Model | Direct Modeling | Deform | Move Point) to grab the center of the region and pull it out or down to form the belly of the sail. Repeat _dmdeformpoint on other points to tweak the shape if desired, say to lift the corners or just to break the symmetry so it looks more natural.
0 -
Thanks everyone for your suggestions
The method I ended up using was using the Loft command.
The attached files give an overview of how I created the sale.0
https://www.youtube.com/watch?v=0xvrPDI1j8E
