Briscad RLM license commands
I'm trying to find detailed information on what is possible and how to set up the RLM license server. Not just for it to work, it does, but to have more detailed control over who gets priority.
I found the "Bricscad V10 - User Guide_network licenses server.pdf" as well as the "RLM License Administration Manual" but neither give me any information that I'm searching for.
It should be possible to set up the server to give priority to some users, isn't it ?
If it is then can anyone point me where I can find detailed information about how to set up the script, what commands are available etc ?
Hi Peter
You can pool network licenses, more info can be found here: https://www.bricsys.com/en-eu/support/#85a=368
Hope this helps!Regards
Mathieu
0 -
Mathieu,
Thank you kindly, that was just the information I was looking for.
0
