Programação Lisp "BricsCAD x AutoCAD"
Good morning everyone
I've just migrated from autoCAD to Brics, and I liked the similarity, but I'm having some difficulty with some routines because it works in autoCAD but in Brics there is an error.
as not described below:
; [2].......MOSTRAR-ALL-IT <<--
; ----- Error around expression -----
; (LET NIL (GETINT "
.... PAUSE") (IF (OR #INDST_PARCL) (PROGN (PRINC "
but this happens in several functions "(defun"
I'm kind of lost ... I do not know how to solunate, apparently everything is correct.
I carry the same routine in AutoCAD and it works perfectly
I'm Brazilian and I speak Portuguese, I'm using Translator, maybe some words out of context but out of context ....
Below is the Lsip routine:
(defun #Mostrar_SetorEGrupo ()
(GETINT "\n..... ") ;;;; only to pause at this point
(IF (/= #Indst_ParcL nil)(PROGN (PRINC "\nSetor: ")(princ #Indst_ParcL )))
(IF (/= #Grupo_Escol nil)(PROGN (PRINC "|Grupo: ")(princ #Grupo_Escol )))
I'm waiting, thank you.
Hi LaudReis
Does this Help ?;; (#Mostrar_SetorEGrupo) (defun #Mostrar_SetorEGrupo () (setq #Indst_ParcL (getint "\nInput Integer : ")) ;;;; only to pause at this point (setq #Grupo_Escol (* #Indst_ParcL 2)) (if (/= #Indst_ParcL nil) (progn (princ "\nSetor: ") (princ #Indst_ParcL) ) ) (if (/= #Grupo_Escol nil) (progn (princ "|Grupo: ") (princ #Grupo_Escol) ) ) (princ) )DoIt: BLADE
DoIt: #MOSTRAR_SETOREGRUPO
DoIt: (#Mostrar_SetorEGrupo)
Input Integer : 21Setor: 21|Grupo: 42
0 -
Thanks Kerry Brown
But I did some testing on here.
to check the results, and I came across the following.when I tested the routine separately before using my "Key / Head" program it works correctly.
But when I'm using my commando (IT) that loads the routine
(Mostrar_SetorEGrupo) it shows the error in this function, ie "there is no error in the function", but something structural or variaves or something of the type.So I post a question, I'm new to BricsCAD but I've been programming in AutoLISP for a long time:
You remember when they migrated to BricsCAD something similar happened, that is, to make errors in routines (defun's) that in AutoCAD worked. (but again I have tested (Mostrar_SetorEGrupo) separately and it works in BricsCAD.As I said it may be something in the structure of my program or in the variaves or something of the type.
If anyone can help me. I already watered in advance0 -
I notice the error message in the OP mentions a 'let' function. Be advised that BricsCAD has a built-in let function whereas AFAIK AutoCAD does not. Try renaming your custom let function.
0 -
@Roy Klein Gebbinck said:
the OP mentions a 'let' function. Be advised that BricsCAD has a built-in let functionWhoa .. when did that happen .. I'll take it off my wish list.
Do you have a link to docs or spec' ??
Regards,
added:
The usage of the OR is unusual.
and:(if (/= #Indst_ParcL nil) ...
could be(if (not (boundp #Indst_ParcL)) ...0 -
This let function is part of the underlying Lisp engine. It may be unwise to use it considering it is indeed undocumented.
Example:
(let ((a 3) (b 5)) (* a b))0 -
Thanks Roy,
May be time to talk to Torsten
0
