Crosshairs Rotated
in 2D Drafting
I have a drawing that somehow has the crosshairs rotated about -33 degrees from zero relative to the world coordinate system. When I try to draw anything orthogonal, it defaults to the rotated cross hairs orientation rather than the coordinate system. How can I rotate the cross hairs back to square with world?
0
For me it looks like you (accidentally) set and activated a UCS.
AFAIK there is a command to re-align the UCS back to World.0 -
You may have a non-zero roll angle in your current view. Use the VIEW command to check view properties.
0 -
To restore the plan view of the WCS (world coordinate system):
- Type UCS then press the Enter key twice
- Type PLAN and again press the Enter key twice.
When UCSFOLLOW = ON, the plan view of UCS or WCS is restored automatically.
0
