How to create sequential numbers on patharray?
in 2D Drafting
Hi,
is there an easy way to number the elements of a patharray (see picture). As of now, I use patharray with a textblock that contains the number one and change all the number manually.
I would be great, if the text would show the distance from the start, i.e. if the distance is 5, the texts should be 0, 5, 10 aso.
0
Or just try this sequential numbering with loads of options
https://forum.bricsys.com/discussion/comment/20107/#Comment_201070
