ACET-SS-DRAG-MOVE failure
I get this message when I try to use this function from the acet library
; ----- LISP : Call Stack -----
; [0]...ACET-SS-DRAG-MOVE <<--
; ----- Error around expression -----
; (EARX:AUX:SPLIT_TXT_LINE MSG "/")
Error: no function definition <EARX:AUX:SPLIT_TXT_LINE> ; expected FUNCTION at [eval]
Regards George
0
which BricsCAD version u use and which arguments for ACET-SS-DRAG-MOVE u use?
The function EARX:AUX:SPLIT_TXT_LINE is only availlable in Express Tools.0
