BLOCKS with Attributes - MATCHPROP for blocks?
Hi all,
I have a dwg with about 20 identical blocks. I would like to use the MATCHPROP command to change the layer for some of the attributes on selected blocks. For instance, about 8 blocks I need to change the attribute color to green from the existing white. These attributes are typically set "by layer" - which is what I want. But, I need to change the layer for the newly edited attributes. I could do this manually, but it's going to be about >100 different attributes.
Any tips or tricks?
Thx and stay safe.
  • Try this lisp code:
    (defun c:MatchAttLyr ( / enm doc lyrLst obj ss)
      (setq doc (vla-get-activedocument (vlax-get-acad-object)))
      (vla-endundomark doc)
      (vla-startundomark doc)
      (if
        (and
          (setq enm (car (entsel "\nSource object: ")))
          (setq obj (vlax-ename->vla-object enm))
          (= "AcDbBlockReference" (vla-get-objectname obj))
          (= :vlax-true (vla-get-HasAttributes obj))
          (princ "\nTarget objects: ")
          (setq ss (ssget (list (cons 2 (vla-get-name obj)) '(66 . 1))))
        (progn
          (setq lyrLst
            (mapcar 'vla-get-layer (cons obj (vlax-invoke obj 'getattributes)))
          (mapcar
            '(lambda (enm / obj)
              (mapcar
                '(lambda (obj lyr)
                  (vla-put-layer obj lyr)
                (cons
                lyrLst
            (vle-selectionset->list ss)
      (princ)
