Jumpy cursor when command is active
I have smooth movement of the cursor within Briscad v20.2.06
The issue is when a command is active, the cursor responds as if it is snapping to a grid (Snap is turned off)
Is there another variable I am missing?
V20.2.06
Windows 10
4k display
Thank you for your response, any are appreciated....
0
I found the solution:
SNAPTYPE to 0 (to nix the dynamic grid
0
