Rounding Off Text for Multiple Textboxes - ANSWERED
Here is what I want to do: Have the user enter a numeric value into a textbox. Upon leaving, the text (a number) will be checked for the number of decimal places. The text will be changed to meet the 2 decimal places required (either add a "0" to the end, or round to 2 place)
Since I want multiple text boxes to do the same thing, I was hoping to have them all use the same _Leave function.
This is my code, but it crashes:
Private Sub txtBodyX_Leave(ByVal sender As Object, ByVal e As EventArgs) Handles txtBodyX.Leave, txtBodyY.Leave,
txtDieBodyX.Leave, txtLidFootThickness.Leave, txtLidBodyZ.Leave, txtDieBodyY.Leave, txtCollBallDia.Leave,
txtBallPitch.Leave, txtBallDia.Leave
Dim senderTextBox As Windows.Forms.TextBox = TryCast(sender, Windows.Forms.TextBox)
Dim txtString As String = senderTextBox.Text, testChar As String, decimalPlaces As Integer, strToNum As Double
Dim roundedNum As String, newText As String = ""
'If the first character is a ".", add a leading 0
If txtString.Substring(0, 1) = "." Then txtString = "0" + txtString
For i As Integer = 0 To txtString.Length - 1
testChar = GetChar(txtString, i)
If testChar = "." Then decimalPlaces = (txtString.Length - 1) - i
If decimalPlaces = 1 Then newText = txtString + "0"
If decimalPlaces > 2 Then
strToNum = CDbl(txtString) 'convert the string to a number
roundedNum = Math.Round(strToNum, 2) 'round to 2 places
newText = roundedNum.ToString
End If
Next
senderTextBox.Text = newText
End Sub
Thanks in advance for any help.
Try looking at Format or FormatNumber.
e.g.
Function NumTxt(num As Single) NumTxt = Format(num, "0.000") End FunctionRegards,
Jason Bourhill
BricsCAD V20 Ultimate
CAD Concepts0 -
Hi Jason, thank you for your response, but I don't think that is the issue.
I should have been more clear.
I did change the For statement to be for i = 1 to txtString.Length as getChar starts the index at 1 (not 0, my bad).
I believe the problem lies in the sender part. I put a breakpoint in that part of the code at "Dim senderTextBox ...." and it allowed me to put a number in the text box, but crashed as soon as the cursor left the textbox.0 -
Ok, I figured it out. (slapping my head)
I was entering a 2 digit number with no decimal and I had nothing to check for that instance.
Here is the code that works (just in case someone ever needs it):Private Sub Textbox_Leave(ByVal sender As Object, ByVal e As EventArgs) Handles txtBodyX.Leave, txtBodyY.Leave, txtDieBodyX.Leave, txtLidFootThickness.Leave, txtLidBodyZ.Leave, txtDieBodyY.Leave, txtCollBallDia.Leave, txtBallPitch.Leave, txtBallDia.Leave 'these are the text boxes that will need to use the same function Dim senderTextBox As Windows.Forms.TextBox = TryCast(sender, Windows.Forms.TextBox) Dim txtString As String = senderTextBox.Text, testChar As String, decimalPlaces As Integer = 0, strToNum As Double, roundedNum As String, newText As String = "" If txtString <> "" Then 'If the first character is a ".", add a leading 0 If txtString.Substring(0, 1) = "." Then txtString = "0" + txtString For i As Integer = 1 To txtString.Length testChar = GetChar(txtString, i) If testChar = "." Then decimalPlaces = txtString.Length - i If decimalPlaces = 1 Then newText = txtString + "0" If decimalPlaces = 2 Then newText = txtString If decimalPlaces > 2 Then strToNum = CDbl(txtString) 'convert the string to a number roundedNum = Math.Round(strToNum, 2) 'round to 2 places newText = roundedNum.ToString End If End If Next If decimalPlaces = 0 Then newText = txtString + ".00" End If senderTextBox.Text = newText 'replace the text in the text box with the text with the correct number of decimal places End Sub0
