Setting Needed: Snap to Increments With No Active Command
Which setting controls the snap behavior to allow snapping to preset Increments while no command is active?
Many thanks,
C. Hill
0
For answer take a look at the discussion:
https://forum.bricsys.com/discussion/36209/snap-and-movement-of-the-cursor#latest
Obviously Bricscad has not the command known from Autocad(c) "SNAPGRIDLEGACY".0
