Brics CAD v21 import settings
Hi,
Is it possible to bring back import settings from previous realase installed on PC?
I have v20 on my PC and installed v21. During the first start v21 asks if I want copy settings.
I clicked "no" since it didn't work out well a year ago (v19 -> v21)...
I wanted to give it a try after looking around v21.
Cheers.
0
If you delete the V21 current user registry key while BricsCAD is not running, then it will prompt again to migrate settings on the next start.
0 -
Thank you Owen, it works.
However unfortunately BC doesn't import settings 1:1...0 -
How to delete: "current user registry key"?0
