How to toggle layfrz to only freeze in veiwport by default ?
Hi
Up until recently, when I used the layfrz button, the selected layer would only freeze in the active viewport, but now for some reason it freezes the layer throughout the drawing.
Is there a variable I can set to make the layfrz command only freeze in the active viewport by default ?
Thanks.
0
I looked up layfrz in the help documents and looks like there is a setting in the command you can use.
layfrz>Settings>Viewports>Vpfreeze
That should toggle Vpfreeze to become the new default so you don't have to keep going into the settings option of the command.More info here:
https://help.bricsys.com/hc/en-us/articles/360006618834-LayFrz0
