Aerial Image assingned to a box.
How does one attach a aerial image to a 3D solid box 1:1?
I want to use this to export to fbx. The image is exact the same size as the solid.
In the mean time i just keep trying some
Thanks!
0
Basically you can create a Material,
apply the image as diffuse/color Texture
and apply a "Texture Size".
I think these are INSUNITS
(Although your image is not quadratic, I think you need to apply
the larger Edge's value)Yes, I tried, it works.
You even don't need to add an Offset from origin,
as Bricscad starts the Texture from an Object Edge.Here is my modified File :
BTW,
You have to reapply the Texture File/Path to Diffuse Map0 -
Thanks ! Worked out
0
