Bim ReferenceFace composition is not working
Can anyone help me?
If i make a wall in Bricscad BIM and i want to place a composition on that wall, The tool 'drag and drop' doesn't work.
So the composition that i want to place does not appear. How come?
Is there a button that i have to put on or off?
Thanks for you're answer.
Greets Ron Dekker (the Netherlands)
0
Hello,
Have you turned on the Render Composition Material in V21 or Level of Detail button in V20? From the Home tab in the Ribbon, they are both in the View section.
0 -
Also, when you apply a Composition too a Wall,
in later Bricscad Versions,
there will come a display hint (green arrows) that ask you to confirm
the Wall/Composition direction. That may need another ENTER.0
