Bricscad on macOS 11 Big Sur
Installed Bricscad V21 few days ago, I'm still working with it with the default settings and crashes with simple commands quite every 30 minutes, especially in layout views..
I work on a Macbook pro mid 2015, i should actually expect slow performance, not have to save the file every 5 commands..
0 -
I'm using v21 on Big Sur on a late 2015 iMac. The program seems fairly stable for most work but when I try to open a second or third drawing using Preview it often crashes, though not every time. This often results in losing some of my toolbar settings. Not sure if this also happens when opening directly from Bricscad. It also crashes more often than not when I try to use the Publish command now, which also drops some of my xrefs of those drawings not open when I publish (I am currently working with Bricsys staff on a support request for this Publish problem).
0
