duplicate layout
Hi, i'm coming from autoCAD where you right-click on any layout tab and then you can copy to the end or put between other layouts the new/copied one.
I cannot figure out how to simply duplicate a layout i have (in the same drawing) with bricsCAD
can anyone help me? thank you
0
Found the solution:
hit "Copy" in the menu after right-click on layout, then follow the instruction on console to give the name to the new copied layout.0
