FIND command : How to search xref's text ?
Hello, I'm moving from AutoCAD to BricsCAD and I'd like to know if it's possible to search text string located in a Xref file ? I don't find any option in the dialog box.
0
You can use DotSoft's DwgSearch Freeware to search for text strings in Text, Mtext (and other named objects) in any drawing in folders, (and subfolders).
0
