Copyclip does not work
I ran into a problem at last stratup. When I press ctrl+C, it does not activate copyclip command, it rather says - Unable to recognize command "cc". I don't remember messing with any command aliases or anything like that. What seems to be the problem here?
  • Anthony Apostolaros
    edited May 11
    It sounds like you have "CC" assigned to Ctrl-C in the Keyboard tab of the Tools>Customize palette, but nothing assigned to "CC" in the Command Aliases tab of that palette.
    If so, just change the "CC" in the Keyboard tab to "CopyClip." Or assign "CopyClip" to "CC" in the Command Aliases tab. Or both.
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
