Highlight Object in Model space,which is visible in viewport
I am trying to Highlight objects which is exists in model space,
but my current space is Paperspace, i use the following code, which work perfectly in AutoCAD,
In BricsCAD the same code got execute, but did't get any results.
below is the snip of code:
Using lock As APPSER.DocumentLock = APPSER.Application.DocumentManager.MdiActiveDocument.LockDocument
Using tr As Transaction = curDb.TransactionManager.StartTransaction()
highlight_obj = New Microsoft.VisualBasic.Collection
For rid = 0 To ListBox1.SelectedItems.Count - 1
Dim AllObj_ids As String() = Room_Step_Details(Int(ListBox1.SelectedItems(rid).ToString.Replace("Room ", ""))).Split(New Char() {","c})
For n = 0 To AllObj_ids.Length - 1
highlight_obj.Add(AllObj_ids(n))
Dim obj As ObjectId = curDb.GetObjectId(False, New Handle(Convert.ToInt64(AllObj_ids(n), 16)), 0)
Dim ent As Entity = tr.GetObject(obj, OpenMode.ForWrite)
ed.SwitchToModelSpace()
ent.Highlight()
ed.UpdateScreen()
ed.SwitchToPaperSpace()
Next
Next
tr.Commit()
End Using
End Using
please advice what needs to be change to achive the result.
Thanks in Advance
I use the highlighting method in the same way. There is no need to switch spaces and call UpdateScreen - these are unnecessary steps. The backlight works great in BricsCAD.
0
