Dimension issue with BricsCAD v20
in 2D Drafting
When I open a drawing (previously worked on using v17 or v19) with v20, some dimensions are out of order and points to 0,0 in paper space. Has anyone seen this and is there a fix?
0
This may be the same issue that was described in the thread "Display issue between older and newer version of BricsCAD (or AutoCAD)" from April 22.
0 -
So far my only work around to this problem is to copy the dimensions then delete them and paste it back in.
0
