How to turn of UCS automatically aligning with 3D object?
Spent a good 20+ minutes but couldn't find the setting that 'fixes' the UCS to one solid point.
I'm having an issue with my UCS 'dynamically' changing when I try to draw a rectangle near another 3D object. The 3D object is slightly out of alignment. The rectangle is drawn on that objects UCS coordinates. If you want to reproduce this, draw a rectangle, rotate it 0.05 degrees, extrude it, then draw another rectangle over or near the object. The rectangle will grab the extrusions UCS coordinates and also be slightly out of alignment.
Thanks!!
Welcome!
It looks like you're new here. Sign in or register to get started.
Welcome!
